1993 Chevy Astro
1993 CHEVROLET ASTRO
TOHARA
1993 Chevy Astro Automatic
car window switch not working air condition switch not working speedometer not working and i check all the fuses and they are all good what could be the problem
Aug 21, 2009 at 6:26 AM
JDL
  • 16,098 POSTS
If none of the power windows work? Check the power window circuit breaker, also use a testlite and see if there is voltage on that circuit, with the key on. Even if any fuses and or circuit breakers are good, if there is no voltage on the circuit, the circuit is dead.
As far as the hvac, are you saying the blower won't even blow, or the air is not cool?
Aug 21, 2009 at 7:48 AM
TOHARA
thanks for the reply about my window as far as the air conditioner its not coming on at all these are the things that happen all in one day my transmission wouldnt change gears it wouldnt catch second gear then my window wouldnot go up nor down and the air conditioner wouldnt come on and the speedometer was register the speed amount i since then ive replace the transmission and still having the same problem
Aug 21, 2009 at 1:44 PM
JDL
  • 16,098 POSTS
Make sure the battery has a full charge and the battery connections are all clean and tight. The feed circuits for both the hvac blower motor and power windows goes hot when you turn on the key. If those circuits aren't hot, I"d have to check the feed to and from the ignition switch.
Aug 22, 2009 at 1:15 AM
