Right side, both (front and rear) turn signals not working. Flasher is ok, bulbs replaced. Dash indicator does not come on.
It started with the dash indicator for the seatbelt was blinking along witht he right signal indicator and turn signals still worked. Now the seatbelt dash indicator does not work and neither does the right turn signal indicator and turn signal lights. Flasher clicks (although it sound sto be an un-uniform clicking).
When I turn the hazard lights switch on, it immediately blows the fuse. How do I test for a short or ground fault? Even if I find the socket that is faulted, how do I fix it?
Apr 20, 2009 at 4:52 AM
