1992 Chevy Astro tune up specs
FREAKYJ316
Engine Performance problem
1992 Chevy Astro 6 cyl Two Wheel Drive Automatic
what is my ignition timing and rpm to be set at
Jun 1, 2009 at 10:08 AM
POET042005
  • 134 POSTS
If your specifications sticker is still readable under the hood your specs should be there. For timing look for were it says BTC and its degrees. I want to say zero is the spec which is to be set at warmed engine temp and regular idle in bypass mode.
Jun 3, 2009 at 4:33 PM
