1992 Chevy Astro Problems after having water in gasoline
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
FISHNATOR
I had a lot of water in my gas. I removed it and put in fresh fuel. I put fuel injector cleaner in. I changed my plugs, fuel pump and filter and my van still will not start.
What should I try next?
May 28, 2010 at 4:43 PM
  • 75,988 POSTS
If you're getting spark -check the fuel pressure if its within specs and also if the injectors are pulsing
May 28, 2010 at 5:03 PM
