1992 Chevy Astro axle to the leaf spring
230,000 MILES • 6 CYL • 2WD • AUTOMATIC
ASTRO_DAVE
The axle some how broke loose from the leaf spring and the passenger side wheel move toward the rear panel and the drive shaft fell out. I can't tell how this is broken. it looks like the bracket that wraps around the leaf spring is broken. how can this be fixed. Do i need to buy a new axle or is this repairable.
Dec 29, 2007 at 8:48 AM
ASTRO_DAVE
[quote:a7cdf8df42="astro_dave"]Suspension problem
1992 Chevy Astro 6 cyl Two Wheel Drive Automatic 230000 miles
The axle some how broke loose from the leaf spring and the passenger side wheel move toward the rear panel and the drive shaft fell out. I can't tell how this is broken. it looks like the bracket that wraps around the leaf spring is broken. how can this be fixed. Do i need to buy a new axle or is this repairable.[/quote:a7cdf8df42]
Dec 29, 2007 at 8:54 AM
