Check fuel pressure with a mechanical gauge, you may also have a malfunctioning EGR system, which will cause stalling and sluggish performance.
Did you clean the IAC valve when you had the TB off? Is the ECM throwing any codes?
If equipped with distributor, check timing and check spark output if equipped with coil paks.
SPONSORED LINKS
Thursday, July 10th, 2008 AT 5:15 AM
