1991 Chevy Astro gas fumes
1991 CHEVROLET ASTRO
ROGEDIAZ18
Smells problem
1991 Chevy Astro 6 cyl Automatic
ihad been smelling strong gas fumes from my astro van i dont from where these fumes are coming from but i sure did left it with a technichian and i thought they fixed the problem but i keep smell gas fumes what seem to be the problem and from where could it come from?
Aug 2, 2010 at 7:59 PM
WILLIAM_STELTER
  • 24 POSTS
Do you smell it inside or outside your van? Outside it could be anywhere. most likely the gas tank at the top. There is a easy patch kit for that. or check your lines. Lines is usually unlikely though but there couly be a clamp loose or just a loose hose. If inside your van just make sure your hub is sealed tightly.
Sep 22, 2010 at 7:42 AM
