1991 Astro van vibration upon acceleration
JERRY L MURRAY
1991 Chev Astro CL AWD EXT. 163,000 miles on a TBI 4.3L. Purchased in 2000 with 110,000 miles. The $6500 van turned into a $13,000 van. Have completed transfer case upgrade - rebuilt trans and front diff. Replaced drive shafts and U-joints, and a broken trans mount. Replaced all steering rods and ball joints.This took care of most vibration, but recently have experienced vibration shudder upon acceleration, and especially when climbing hills. It is a drone noise that can be heard, and felt under the front buckets when driving. Highway is smooth sailing when on level surfaces. Could it be the internal engine balance that you mentioned in another member's Q? Might I use a different transfer case fluid that would help?
Jun 28, 2007 at 7:01 PM
THEONE1979
your vibration actually comes from your transmission
I recomend you to take it to a shop for a diagnosis
but i belive its in your 3rd gear
what happens is your 3rd gear is worn out and it shouddes when going to 4th gear or you might not have 3rd gear no more
Jun 16, 2008 at 10:31 AM
