HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Astro
Engine
Throttle Body
1990 Chevy Astro fuel
RF42
MEMBER
1990 CHEVROLET ASTRO
6 CYL
2WD
AUTOMATIC
200,972 MILES
No fuel to the throttle body
Thursday, November 12th, 2009 AT 1:43 PM
JDL
MECHANIC
Welcome to the forum, TBI fuel system? Use a gage and check fuel pressure. When you first turn on the key, no crank, can you hear the pump run for a few seconds? Any trouble codes?
SPONSORED LINKS
Thursday, November 12th, 2009 AT 2:10 PM
Please
login
or
register
to post a reply.
Related Throttle Body Content
Fuel System
I Get Fule To High Pressure Side Of Tbi But None On Return Side. No Fuel To Injectors. Will Start If I Prime Tbi Willnot Stay Running.
Asked by
kd7doa
1994
CHEVROLET ASTRO
GUIDE
Throttle Body Service
The throttle body or throttle actuator as they are called on newer cars is used to meter the engine air intake thus controlling the engine RPM and power output via the gas...
Motor Mounts
I Have A 1990 Chevy Cheyenne 1500 Heavy Half Ton With A 4.3l V6 In It And A Granny Four Speed Transmission. I Pulled The Engine And I Am...
Asked by
Montana40691
1990
CHEVROLET ASTRO
When I Start My Truck It Sounds Like The Fan Belt...
When I Start My Truck It Sounds Like The Fan Belt Squeeling, Is Something Going Out?What Can I Do?
Asked by
Anonymous
1 ANSWER
1990
CHEVROLET ASTRO
1993 Chevy Astro Fuel Pump Harness Keeps Shorting Out
I Am On My 7th Harness In 18 Months. This Last One Only Lasted 2 Weeks. The Local Mechanic Has No Clue And Is Refusing To Put Another One...
Asked by
janah7
1993
CHEVROLET ASTRO
Vacuum Hose Diagram
I Am In Need Of A Vacuum Line Diagram If At All Possible I Have Some Lines I Can't Find Where They Hook Up.
Asked by
jipjoker
2 IMAGES
2003
CHEVROLET ASTRO
VIEW MORE
SPONSORED LINKS
Service a Throttle Body Housing Ford
How to Build a Ford 302 Small Block - Part 10
Online car repair manuals
