1990 Chevy Astro blower motor problem
300,000 MILES • 6 CYL • AWD • AUTOMATIC
DRE411
My Astro has a problem with the a/c system. The rear fan blows but not hot air and the front fan doesn't blow at all. when the car is moving you can feel warm air coming from the vents in the front. any help would be appreciated. Thank you
Jan 10, 2009 at 6:02 AM
  • 110,248 POSTS
Hi:
Chances are you need to replace the blower motor resister. To check, you need to check for power to the motor itself. If you have power, you need to replace the motor. If there is no power, move to the resister.
Jan 10, 2009 at 12:09 PM
