Power passenger window could not roll it up or down from the drivers side
RAMJET2573
  • 1989 CHEVROLET ASTRO
My window will not work. When I noticed it was not working a could not roll it up or down from the drivers side. Then tried the passengers side and it went down but not back up no power at all. All my other locks and windows work fine. A friend replaced switch and power motor still will not work. Any help would be appreciated. Thanks
Wednesday, December 10th, 2008 AT 2:00 PM
RAMJET2573
It was the master switch on the driver side, thanks for your help
Friday, December 12th, 2008 AT 5:42 PM
  • 109,885 POSTS
Hi:
Which switch did you replace? Also, when you said switch replacement did you do the drivers side master switch?
Tuesday, December 16th, 2008 AT 5:13 PM
RAMJET2573
Both switches and yes had power both ways. Before iit happened olny had power on passenger side and when it went down would not go up. Thanks
Tuesday, December 16th, 2008 AT 6:48 PM
  • 109,885 POSTS
Hi:
Wow. You replaced both switches and the motor and it still doesn't work? You have me stumped. If you are getting power to the motor (both ways) it should work. For the heck of it, try to run a ground strap from the motor to the door. Also, If you run 12 volts to the motor for a separate power supply like an extra battery, does the motor react?
Let me know. I love the challenge of an electrical problem.
Tuesday, December 16th, 2008 AT 7:27 PM
RAMJET2573
It was the master switch on the drivers side. Thank you
Thursday, December 18th, 2008 AT 5:44 PM
