1989 Chevy Astro Door locks un locking
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRONCO226
The electric door locks are trying to unlock on there own while the van is setting off with no key in ignition. You can see them trying to go into the unlock position when they are already there. I had to recharge battery because it pulled it down
Sep 1, 2010 at 1:55 PM
GMTECH
  • 537 POSTS
Try disconnecting the power lock switches to see if they stop acting up. Also wiggle the door boot from the door to the body to see if the change in operaton
Oct 26, 2010 at 7:55 PM
