1989 Chevy Astro dome lights, cig lighter, glove box lights
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
SOUTHBOUND
. i was using cig. lighter heater/defroster and shut it off when the car was not running(i normaly do so while it is still on) something tripped/shorted and now my cig lighter, inside lights, and radio/ radio lights do not work. there is power going to the radio, i can hit the poser button and the speakers get power, but not the radio itself. also my dome light can be set to an on position with my dimmer wheel/switch, and while i can dim my dash lights still, i can not turn on my dome lights. i have checked my fuses and they are fine. i do not have a second fuse panel that i know of, and am not sure where my circut breakers are, or my inline fuses.
Jan 6, 2009 at 7:23 AM
  • 55,562 POSTS
hi, do you have power at most of the fuses in the fusepanel when the key is in the "on" position?
Jan 7, 2009 at 1:57 PM
ASTRO GIRL 1
that happened to my van too any ideas
May 13, 2011 at 12:29 AM
  • 55,562 POSTS
Its sounds like the fusible link has failed. Please check and get back to us. :-)
Jul 5, 2011 at 7:18 AM
WRENCHTECH
  • 20,760 POSTS
You'll find the fusible links at the starter with the main cable.
Jul 5, 2011 at 8:06 AM
