1989 Chevy Astro
24,000 MILES • 6 CYL • 2WD • AUTOMATIC
GERRYONTHEGO
one off my rear brake line broke wild i was driving and i had no brake fluid all i had is power sterring fluid . so went and by a new master-cylinder had the new master-cylinder bled at the garage shop.so i install it and now there no fluid comming trou the combination valve. it only bleed the left caliper only. no fluid come to right caliper. and nothing at the rear wheel cylinder.
Mar 1, 2010 at 9:37 AM
  • 110,251 POSTS
Did they flush the system of the PS fluid? When bleeding the brakes, are they starting at the r-rear then working to the l-r, l-f, r-f?
Mar 12, 2010 at 2:41 AM
