1988 Chevy Astro heater switch
300,012 MILES • 6 CYL • 2WD • AUTOMATIC
OLIVIA9898
i have replaced the blower motor on my heater and also replaced the switch inside that turns it off and on and it still does not blow out when you turn it on. i don't know what eles to check. it gets hot and you can feel it coming through the vents you just can't turn it off or on. what should i check next? this is the second motor and the air is not on there anymore.
Nov 10, 2008 at 3:47 AM
  • 110,248 POSTS
Is there power coming from the switch? Is power getting to the motor? Did you replace the blower motor resister?
Nov 12, 2008 at 3:56 AM
OLIVIA9898
Hi Joe, thanks for your response to my question. Yes there is power on the inside and outside. we checked it with a tester, and put a new blower motor on it, an a water pump that went out. i also put a new control switch on the inside. you can feel the heat coming through the vent. what do you mean by resister?
Thanks
Mary
Nov 12, 2008 at 11:42 AM
  • 110,248 POSTS
Hi Mary: The blower motor resister is where the power goes from the switch before it gets to the blower motor. It could cause the blower motor to not function. The resister is located on a bracket on the right (passanger) side. I tried to upload a picture of it for you. I hope it works. (first try)
https://images.2carpros.com/forum/automotive_pictures/249084_graphic_resister_1.jpg
of the engine compartment. Let me know if you get the picture and if it helps. Let me know if you don't get it and email me with you email and I'll send it as an attachment. (if you need it) Joe
Nov 12, 2008 at 2:51 PM
  • 110,248 POSTS
Hi Again, Mary. Sorry, I sent you the picture of the relay. There is no picture of the resister. However, I can tell you it is located in the blower housing near the motor.
Sorry about the confusion. Computers drive me nuts.
Nov 12, 2008 at 2:56 PM
OLIVIA9898
thanks again. we got it fixed the ground wire wasn't grounding. thanks 4 your help.
mary
Nov 14, 2008 at 3:49 AM
  • 110,248 POSTS
Hi:
Great news! A bad ground will stop anything. If you every have any questions in the future, let me know. Also, where was the bad ground located and how did you find it?
Nov 14, 2008 at 5:17 AM
