1987 Chevy Astro tune up
REGLOK37
Engine Performance problem
1987 Chevy Astro 6 cyl Two Wheel Drive Automatic
hey i had a major tune up about two weeks ago and before it got serviced it ran fine now it runs bad can you help!
Sep 19, 2010 at 5:42 PM
  • 75,988 POSTS
What do you mean by runs bad? Explain yourself maybe we can help, what you gave is not enough to work with and be specific on the problem
Sep 19, 2010 at 5:48 PM
REGLOK37
hello i had a major tune up about a month ago and about two weeks after i got it done now my car runs sluggish does that come from the fuel pump or fuel injection? i work in LA and i really need to know what it is can u help me?
Oct 22, 2010 at 3:01 PM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay use Seafoam fuel injector cleaner and run it thru-problem could also be the wrong type of plugs on it or not gapped properly-check it
Oct 22, 2010 at 4:49 PM
