1987 Chevy Astro rear door handle is disconnected
DOGGIETALK
  • 1987 CHEVROLET ASTRO
  • 6 CYL
  • 169,000 MILES
Is there a way to get the rear door open without completely wrecking the door? The handle has become disconnected from the rod. It will lock and unlock with the key but won't open.
Tuesday, August 31st, 2010 AT 7:13 PM
HMAC300
  • 48,601 POSTS
Ther should be an access panel on the inside that is removable or a panel anyhow. Probably a clip has broken as they are usually plastic. All you need do is get a new clip, they may be available at any auto parts store. Then replace that put eh rod back in and the door should open.
Tuesday, August 31st, 2010 AT 7:39 PM
