You need a noid light or you can use a test light
turn ignition ON test disconnect the injectors and test for battery power at RED and WHITE wires
you should have battery power if not check fuses and wiring harness
if power OK
need to check if the ECM pulsing the injectors
place the one side of the test light at a battery positive side and ask a helper to crank the engine for you as you checking if the test light blinking when on LT. GRN or BLUE wires
let me know
Wednesday, June 10th, 2009 AT 5:16 PM
