1987 Chevy Astro
1987 CHEVROLET ASTRO
STARDIRECTOR
Transmission problem
1987 Chevy Astro Automatic 100,00 miles
Recently had the transmission checked because it was low in changing gears -- the mechanic replaced the fluids
today I was driving it and when I got ready to use the reverse shift on the van, it did not work
I drove the van forward - it worked - It then only drove only 30 miles per hour would not go faster
after a while it then went to 50 miles per hour
which is where I was driving the vehile
is this a transmission problem or what do you think
May 19, 2008 at 3:57 PM
  • CAR REPAIR CONTRIBUTOR
Check the throttle position sensor and the vehicle speed sensor-the computer uses these signals as an indications of throttle and governor pressures If it checks out-you have an internal problem with the transmission
May 19, 2008 at 4:15 PM
