1986 Chevy Astro with 4.3 engine--no electricity at fuel i
SLOW TEXTER
Electrical problem
1986 Chevy Astro 6 cyl Two Wheel Drive Automatic 150k miles
There isn't any electricity at the fuel injectors? I have checked all fuses- they are good. I have also replaced fuel pump relay and ignition control module. Oh and also replaced fuel pump. I also have put a used ecm/computer in van. Still there isn't any spark at injectors? Should both sides of injector be hot?? Can you help me out with any ideas? Thanks
Jan 22, 2009 at 1:31 PM
  • 75,988 POSTS
When key at run one of the injector wire should be hot-if you're getting power to the injector and its not pulsing could be the computer ground drivers-also test the injector/s
Jan 22, 2009 at 5:37 PM
