1985 Chevy Astro Clutch?
53,000 MILES • 4 CYL • 2WD • MANUAL
JIMMYDRUMS70
My van won't go into gear while running, or shift while running.I replaced the slave cylinder and bled the system-still won't go into gear. I can put it in gear and start it, but it still tries to move with the clutch pushed in. It isn't leaking hydraulic fluid....any ideas? Master cylinder? Pressure plate?
Jan 22, 2009 at 1:21 PM
  • 75,988 POSTS
Double check the clutch master cylinder for internal leak if okay -You need a clutch assembly
Jan 22, 2009 at 7:50 PM
JIMMYDRUMS70
OK. Thanks!
Jan 22, 2009 at 11:15 PM
