Changed TPS, idle control valve, checked fuel pump. any suggestions on what to do next?
Jul 8, 2019 at 1:04 PM
✓Experienced Mechanic
Welcome to 2CarPros.
Have you checked for both spark and fuel to the engine? Try this. See if it starts for a couple seconds using starting fluid. If it does, then it is a fuel related issue. If it doesn't, suspect it is ignition related.
Take a look through these links and see if they help.
