Checking on scantool STFT 2 shows dead what does it mean?
180,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
PCMENTOR29
  • 177 POSTS
My problem is I get p0306 and sometimes p0174. The #6 cylinder won't fire. It has good spark, compression and the injector checks ok with opening and holding, ohms, and noid. I was reading a troubleshooting guide on this engine and tried to hook up my laptop and ELM scan tool. I tested spraying some carb cleaner to test the O2 sensors and they seemed to respond. From this picture can you tell me why the STFT No 2 is -1 across the board? Thanks.
Jun 30, 2014 at 11:13 AM
HMAC300
  • 48,601 POSTS
check yoru fuel pressure with a gauge probably low autoparts rent it.
Jun 30, 2014 at 11:23 PM
