checking and recharging my A/C system
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
LINDA ALCANTAR
don't know where the ports are located under the hood.
Jul 18, 2021 at 7:29 AM
SQM
  • 6,383 POSTS
If you are trying to recharge the AC system, you will need to use the low pressure side for the DIY kit. I have attached pictures as well as some helpful articles:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/air-conditioner-leak-detection
https://youtu.be/4EqdrBVb0sY
Jul 18, 2021 at 8:11 AM
LINDA ALCANTAR
Thank you this was great. My boyfriend is way stubborn and would never ask me on the other hand. i love to learn so who's really dumb. Not me i ask question and get the problems solve. thanks again.
Jul 18, 2021 at 8:29 AM
LINDA ALCANTAR
Okay, my boyfriend he didn't even get to turn the car on . The can or where he connecting it to start to spray out. And he had it on there good he said. Do you know what could be the problem?
Jul 18, 2021 at 8:41 AM
SQM
  • 6,383 POSTS
If you are trying to recharge the A/C system you will have to start the car and turn the A/C on to MAX. It helps if the recharging bottle comes with a pressure gauge, as too much pressure will make the A/C not work.
Let me know what you find out.
Jul 18, 2021 at 8:59 AM
LINDA ALCANTAR
Okay, well i guess someone told him he needs a new A/C system. is that hard to put in yourself?
Jul 18, 2021 at 9:36 AM
SQM
  • 6,383 POSTS
To install a new A/C system it does require few special tools and little bit of know how.
There are several components needs to be changed out, depending on the issue. It could be just the A/C compressor, but then again typically few other items like accumulator, condenser etc. gets changed as well for a deflective A/C system.
Here is few good articles that might help you decide:
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
https://www.2carpros.com/articles/replace-air-conditioner-compressor
This is a general guide of changing out A/C compressor:
https://youtu.be/Km63z9bsdhc
Let me know of any questions.
Jul 18, 2021 at 9:48 AM
