Had a power surge, the high beams, blinkers, heat/AC stopped working?
2015 MAZDA CX-5
65 MILES
JEREMIAH HOPKINS
MEMBER
1 POST
Had a power surge..now my high beams,blinkers,heat/AC stopped working. Checked the fuses now what?
Nov 14, 2023 at 1:23 AM
✓Experienced Mechanic
Can I ask how the power surge happened? Also did you check the main fuses for power here are the locations, if these fuses are okay let's check for power coming from the start stop unit.
Here is a guide to help and the wiring diagrams to help you see what I am talking about:
Well, looking at that fuse is connected to the battery and then putting it back together or who knows. Everything up and working again woo-hoo. thanks for your help. PS. It all started from putting in a fuse tap....
Nov 16, 2023 at 2:09 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
