Subtle misfire and a warning:Check Vehicle Stability Control System
46,000 MILES • 2WD • AUTOMATIC
CHRISCHUNG221
  • 17 POSTS
So, my dad took his car to Valvoline to get an oil change. After pulling out, he noticed it had a subtle misfire and a warning came on the dash: Check Vehicle Stability Control System. I plugged in my little blue driver obd2 scanner, and the codes read as follows:
P0171 1 confirmed, 1 pending, 1 permanent.(System Too Lean Bank 1)
C1201 1 Electronic-Controlled Power Steering Code. Status: Current/History.
U0100 1 Air Conditioner code Status: Current/History. Lost Communication with ecm/pcm"A"
3 Engine Codes:
P0171, P1605, P1604
B2312(D-Door Motor Code)
B2312(1 RR-Door Motor Code)
Did Valvoline sabotage the car or something, lol? This is so random. Any advice would be much appreciated. I'm no expert, but always willing to tinker.
Thanks!
Mar 26, 2020 at 10:53 AM
  • 110,248 POSTS
Since he noticed a slight misfire and then the light came on, I suspect the problem is related to the P0171. A lean fuel mixture will cause that. Chances are they left a vacuum hose off, didn't properly attach the air box / air intake between the throttle body and air filter box or something else that has created the leak. If unmetered air is getting into the combustion chamber, the result will be a lean mixture.
Here is a link that explains how to locate and repair a vacuum leak. Take a look through it and let me know if it helps.
I will watch for your reply.
Mar 26, 2020 at 11:00 AM
CHRISCHUNG221
  • 17 POSTS
Bro! Thank you so much. You are a blessing. Opened the hood, and there it was staring me in the face. A vacuum hose that looks like it went into the air filter area was totally off. Hooked it back up. Turned the car on, the VSC warning was still on, but drove it once around the block, and it went away. Check engine light is still on nevertheless, but I'm hoping it will go off after he goes to work tomorrow. If not, will let you know, but thanks again my friend!!
Mar 26, 2020 at 11:21 AM
  • 110,248 POSTS
You are very welcome. I had a feeling that is what happened. As far as the check engine light, it will eventually go off, but it may take a little time. Other than waiting, if you have or know someone with a scanner, just erase the codes and it will be gone. (actually you have a blue driver) I just remembered that. You can clear the codes with it. ( is that the one that is blue tooth with your phone? ) If so, it should do this for you.
Now, tell the Valvoline shop they caused you a problem by doing this. Hopefully, they will not charge you for the next service. LOL
Take care and feel free to come back anytime you need something in the future.
Mar 26, 2020 at 1:21 PM
CHRISCHUNG221
  • 17 POSTS
Thanks so much Joe!!! Will do. God bless!
Mar 26, 2020 at 10:51 PM
