Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Malibu
Drivetrain
Transmission
Fluid
Add Fluid
Check transmission fluid level?
2008 CHEVROLET MALIBU
189,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BLAKESLIST
MEMBER
Hi, where is the transmission fluid level plug located?
Thanks in advance,
Blake
Dec 20, 2020 at 3:47 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
As far as visually checking the transmission fluid level I found this video for you.
https://youtu.be/ualklGHjBYM?t=3
I've attached picture steps below describing how to check the fluid level as well. Hope this helps and thanks for using 2CarPros.
Images (Click to enlarge)
Dec 20, 2020 at 5:28 AM
BLAKESLIST
MEMBER
Hi Danny,
I wasn't sure, but you confirmed it for me. Thanks a ton.
Blake
Dec 20, 2020 at 5:45 AM
DANNY L
You're welcome!
Thanks again for using 2CarPros and hope you will use our site again in the future.
Danny-
Dec 20, 2020 at 6:33 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
