no oil pressure. how can I check oil pump without removing pan?
Feb 17, 2018 at 6:30 AM
✓Experienced Mechanic
Good evening.
You can remove the oil pressure sending unit and insert a manual gauge into the port and measure the pump output. this is the only way without dropping the pan.
Feb 17, 2018 at 9:40 AM
