check oil light
2002 DODGE INTREPID
150,000 MILES
CJARRELL1
When the car idles the check oil light comes on but when I check the oil it is okay. Could this be the oil pump?
Apr 18, 2013 at 10:23 AM
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
5psi minimum at idle. You might be able to double-check oil pressure at idle? Use an analog pressure gage in place of oil pressure sending unit.
Apr 18, 2013 at 11:46 AM
