Check light is not turning off
67,000 MILES • 3.0L • 6 CYL • TURBO • 2WD • AUTOMATIC
AUSTINO
  • 231 POSTS
Good afternoon, whenever time I drive the car down the road, it only shifts two times and if I try to drive it hard it's not taking any gas from me, it just throttles high. When I switch it off and start it again, it gets going. Could the check light that does not turn off cause this? or could a low transmission fluid in the vehicle cause this problem also? Let me know what you think. thank you in advance.
Mar 11, 2019 at 4:25 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The check engine light isn't the cause, but rather, it is telling you there is a problem. What you need to do is have the computer scanned to identify diagnostic trouble codes. Here is a quick video that shows how it is done:
https://youtu.be/b2IJGfImVvw
Now, I realize most people don't own a scanner. However, often times parts stores will do it for free. You need to have this done. Once we get the diagnostic trouble codes, we will then know where to focus.
Next, low transmission fluid can cause problems too. Here are the directions for checking transmission fluid level. No longer is it a 10 second check using a dipstick. Here are the directions. All attached pictures correlate with these directions.
_____________________________
Transmission Fluid Level Check
Special Service Tools
picture 1
Adaptor 307-452
Check
1. The follow steps must be observed before starting the transmission fluid level check.
- The vehicle must be on a horizontal ramp.
- The parking brake must be applied.
- The engine must be running for 2 minutes with the transmission selector lever in the "P" position.
2. Connect the Jaguar Approved Diagnostic System.
3. Make sure the transmission selector lever is in the "P" position.
NOTE: Make sure the transmission fluid temperature is below 30 C (86 F) on the Jaguar Approved Diagnostic System.
4. With the engine running and the foot brake applied, circulate the transmission fluid by:
- Moving the transmission selector lever to the "R" position
- Waiting for three seconds.
- Moving the transmission selector lever to the "D" position
- Moving the transmission selector lever to the "P" position
5. Raise and support the vehicle.
picture 2
6. Remove the transmission undertray.
7. Place a suitable container under the transmission fluid filler plug.
WARNING: Make sure that care is exercised near rotating parts. Failure to follow this instruction may result in personal injury.
picture 3
8. With the engine running, using the special tool remove the transmission fluid fill plug.
- Remove and discard the transmission fluid fill plug.
NOTE: Use transmission fluid meeting Jaguar specification.
picture 4
9. If the transmission fluid does not come out of the transmission fluid filler plug hole the transmission fluid level is insufficient. If this is the case add the transmission fluid in 0.5 liter units into the transmission fluid filler plug hole until fluid comes out.
NOTE: Make sure the transmission fluid temperature does not exceed 50°C (122°F). If the transmission fluid temperature does exceed 50°C (122°F) stop the transmission fluid level check and allow the transmission fluid to cool until the temperature is below 30°C (86°F).
picture 5
10. Allow the transmission fluid to drain from the transmission fluid filler plug hole until the flow almost stops.
NOTE: Install a new sealing washer.
picture 6
11. Using the special tool, install the new transmission fluid fill plug.
CAUTION: Make sure the transmission fluid fill plug is tightened to the correct specification. Failure to follow this instruction may result in damage to the vehicle.
picture 7
12. Using the special tool and a torque wrench, tighten the transmission fluid fill plug.
- Tighten the transmission fluid fill plug to the torque given by the calculation
- To make sure the transmission fill plug is torqued to the correct specification. Using the special tool and a torque wrench the following calculation steps must be followed.
Step 1.Multiply 35 Nm by the effective length of the torque wrench (1).
Step 2.Add the effective length of the special tool (2) to the effective length of the torque wrench (1).
Step 3.Divide the total of step 1 by the total of step 2.
Step 4.Set the torque wrench to the figure arrived at in step 3.
- Tighten the transmission fluid fill plug to the torque given by the calculation.
picture 8
13. Remove the special tool.
14. Remove the container.
picture 9
15. Install the transmission undertray.
16. Lower the vehicle.
17. Disconnect the Jaguar Approved Diagnostic System.
Let me know if this helps. Also, have the computer scanned to identify diagnostic trouble codes. It will be very helpful.
Mar 11, 2019 at 12:03 PM
AUSTINO
  • 231 POSTS
Thank you so much sir.
Mar 12, 2019 at 9:33 AM
  • 110,248 POSTS
Happy to help. Let me know if you have other questions.
Mar 12, 2019 at 9:59 AM
