Check haybrid system on dashbord?
105,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
FADI ZUDE
After washing my car check hybird system on dashboard and the car move whithout any problem.
May 8, 2025 at 4:53 AM
CANNON1349
  • 861 POSTS
Hello, did you happen to wash the car with it running, or in the "on" position? Also, do you have a scan tool of any kind? If not, they can be purchased relatively cheap from Amazon for about $20. We will need to scan for the codes stored in the memory. Alternatively any parts store should be able to scan for you for free. A hybrid message means there is a code(s) stored in the hybrid computer memory. This will also give you information if there is any problem with the hybrid battery pack. In most cases this message will not go away without clearing the code. So if you or someone can clear the code, it may not come back due to the circumstances.
Hope this helps,
William
May 8, 2025 at 10:31 AM
