check gauges light turns on
232,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TOMJJONAS
  • 10 POSTS
My check gauges comes on every now and then while driving if i put it in neutral the light goes off. What is this light for and what does it do or for?
May 16, 2022 at 6:39 AM
  • 55,851 POSTS
This happens when the gauge response starts to become too slow, are all the gauges working? I would check the coolant level and engine oil to start and monitor the engine oil pressure and temperature. If all else fails a rebuilt cluster would fix it. This video will show you how to change it out:
https://youtu.be/_HEC44xENxw
Please run down this video and report back.
May 16, 2022 at 12:30 PM
