Check engine light flashing and traction control on
160,000 MILES
ROBLEE92
My check engine light is flashing, and the traction control is also on. Car is shaking a little bit also. I tried tightening the gas cap and resetting the battery already.
Jun 5, 2022 at 3:03 PM
SQM
  • 6,383 POSTS
The check engine light can come on due to any number of reasons. When the on-board diagnostics detects any fault within the engine management system it triggers the light.
It could be due to misfiring, faulty sensor, emission issues, vacuum leak etc.
When the check engine light gets illuminated, a good first step would be to scan and retrieve the trouble code(s). That can help with the diagnostics.
Most auto parts stores have code readers that you can use to retrieve the code for the check engine light.
Let me know what code you are able to retrieve, or if you have any questions.
Jun 5, 2022 at 3:41 PM
