2001 Toyota Camry check engine light
JON53190
  • 2001 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 56,000 MILES
My check engine light is on. I have just over 56000 miles on the car. The oil in the engine is clean and full. Do I need to take the car to a dealer to have the light re-set?
Sunday, May 18th, 2008 AT 1:29 PM
  • 31,937 POSTS
Hi there,
Any work shop can check the set fault code. You will need to have the fault rectified or the ECU will keep setting the fault and the light will not go out.
Mark (mhpautos)
Sunday, May 18th, 2008 AT 5:01 PM
