First I should start by saying this issue only happens when the check engine light is on.
The car from a complete stop is very slow to drive. If in constant motion does get a bit faster. It will go in reverse perfectly fine though. Also the AC will not work when this issue is going on.
I got car two weeks ago (knowing the issue but not thinking he meant it was everyday because he said only when light is on) oops. First couple days it was hard to start.
Hard to start in the sense it turned over fine but dies out moments later or when put into gear.
Recent I seen a cracked hose from air filter box at end where clip was. I cut end off and put hose on further and re-clamped it. So now it starts with no issues or check engine.
However, I drive for two minutes then it comes on and car is sluggish again.
The weirdest part is this is only on way to work. After work usually 3:00 pm car starts and drives fine for hours and no issues. Only once or twice has it happened on way home.
If it was a vacuum leak should it not be happening no matter what time of day it is. I was searching vacuum leak only because I seen that cracked hose but seems to be another issue.
Sensors? But why would a sensor be bad in AM but work in afternoon?
Please help
Please help
Oct 27, 2018 at 1:16 AM
