Two error codes PO446 and PO446 PD. How much would it cost to fix it?
Wednesday, July 27th, 2016 AT 6:19 AM
HMAC300
MECHANIC
Check locally because this says vent to evap purge is blocked, but often times it is a fuel pressure sensor which is in the tank. So will need to be physically checked out.
