Check engine light on
2007 LEXUS IS 250
129,000 MILES • 2.0L • V6 • 2WD • AUTOMATIC
KELVIN MANDA
The light for check engine has been on despite checking, airflow sensor, cleaning the throttle and changing the plugs. When I start the engine, the vehicle can only move with the engine check on.
Other lights that are showing on the dashboard a triangle like light, skidding light, AFS light.
Feb 17, 2022 at 8:39 AM
  • 110,240 POSTS
Kelvan,
Have you had the computer scanned for diagnostic trouble codes? That is where I would recommend starting. Since the light is on and the lights you mentioned are lit, there are several different things going on. The skidding light indicates a traction control issue, the AFS is related to the adaptive front lighting, the triangle (if red) is usually an indication that there is an issue with things such as the tire pressure, low key fob battery, washer fluid is low and so on. With that light on, there should be a definition in the message center indicating specifics for its being on.
What I would suggest is to have the scan done on the vehicle to get the codes. They will help point you in the right direction. Here is a link explaining how it is done:
If you are unable to have that done, let me know. We will need to start checking different components.
Take care and let me know what you find.
Feb 17, 2022 at 9:06 AM
KELVIN MANDA
Thanks Joe.
The scan was done, and it gave code p0102. The mechanic tried to change MAFS, but nothing has changed. The engine loses power sometimes.
Feb 17, 2022 at 9:39 AM
  • 110,240 POSTS
The code indicates low voltage to the MAF. Wiring and connectors need to be checked.
If you look below, I attached diagnostics. The sensor is likely not the cause, but rather a connection or damaged wire.
Take a look through the diagnostics and let me know if you feel comfortable performing them.
Feb 17, 2022 at 10:13 AM
