Check engine - no codes or cannot connect
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
ILIFTW8Z
  • 5 POSTS
I have check engine light on. One shop got no codes when checking, another cannot get scanner to communicate with computer. Drives fine. Sometimes blinker makes noises when flashing. Also, researched that 1995 should be obd1, but I have an obd2 port under steering column. Is that a dummy? Or am I? What is going on? Help!
Oct 25, 2017 at 1:25 AM
STEVE W.
  • 15,399 POSTS
Yep, it is a fake. (not totally it was in the new design and does allow connection with a scan tool with the correct software, but most will not have that)
Open the hood and look on the drivers side fender and you should find the EEC-IV test connection. You can use the "light flash" method or connect the proper OBDI scan tool to get more data.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Oct 25, 2017 at 4:47 AM
ILIFTW8Z
  • 5 POSTS
Thanks. Will try that and report back.
Oct 25, 2017 at 5:33 AM
ILIFTW8Z
  • 5 POSTS
Hi Steve W. Here are the codes I got:
Engine Off:
332 Insufficient ERG Flow
558 ERG Regulator Valve Selenoid circuit failure
Engine On:
116 Engine Coolant Sensor Out Of Range
332 EGR did not open / respond
538 Sys didn't receive Goose test
536 Break on off open or shorted
632 TCS Should be cycled once between goose test
Thoughts on $$$$ to fix and what is needed?
Trying to find a reasonalbe mechanic in West LA, Ca.
Nov 11, 2017 at 8:25 AM
STEVE W.
  • 15,399 POSTS
OOF... That's a few codes BUT only 3 really matter and of them one is likely causing another code.
Codes 332 and 558 are related. 558 is the EGR vacuum control solenoid. Either the wiring or the solenoid itself. If it doesn't operate properly the EGR doesn't work and you get the 332 code because the EGR isn't being properly controlled by the PCM. Check the wiring to it and you could test it's resistance as well if you have a Volt Ohm Meter. Damaged wiring or corrosion cause more codes than bad parts.
Resistance in the EVM coil 20-70 ohms
Code 116 points at the engine coolant temp. or intake air temp. being out of self test range. That could be for several reasons, bad sensor, loose connection or that the temperature during the test was under 50 degrees.
For both the test involves checking the wiring and connections and using a meter to back probe the connection and see what voltage each sensor is actually sending.
One or both are why the CEL light is on as both will call for it. Both can easily be diagnosed with a decent VOM and a couple sewing needles.
This video shows how you can test the wires with the sensor/connector still in place.
https://www.youtube.com/watch?v=yuzVBd9Hk7k
536, 538 and 632 are simply because you probably only pulled the codes themselves. Ford has a complete cycle you do with the factory scan tool where you plug it in, then get KOEO codes, then start the engine and look at KOER codes and do things like step on the brake, the gas, shift through the gears, and some others. If you didn't follow those procedures you get those codes.
Easy way to know those three don't matter,
536 - do the brake lights work? yes> code doesn't matter as that is what it tests for, brake switch on/off during the test. If you don't press it OR you hold it on it sets the code.
538 - If you step on the throttle does the engine rev up? Yes> code doesn't matter basically for the same reason as above, no throttle blip during the KOER test.
632 - Does the transmission change gears and the back up lights work? Yes> guess what.....
Nov 12, 2017 at 7:20 PM
ILIFTW8Z
  • 5 POSTS
Steve W! You were right!! Everything revolved around wiring! Fixed for $180 AND PASSED inspection/smog. Thanks so much!
Nov 13, 2017 at 10:20 AM
