Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Suzuki
Vitara
Warning Lights
Check Engine Light
Check engine light on
2004 SUZUKI VITARA
80,000 MILES • 6 CYL • 2WD
NORA ALLEN
MEMBER
1 POST
Check engine light on showing misfire on six. Replaced all plugs check engine light still on.
Jun 25, 2018 at 10:43 PM
Experienced Mechanic
Good morning.
Besides plugs other possibilities are:
1. Low compression.
2. Vacuum leak at the intake manifold.
3. Coil or wiring at the coil.
4. Clogged injector. do not use additives in the fuel as they have no effect.
5. Quad driver in the PCM not commanding the injector to fire.
Jun 25, 2018 at 10:59 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
