Check engine lights
9,500 MILES
BECKY BALDELLI
Two check engine lights came on. One has a downward arrow. I just had my oil changed.
Feb 21, 2018 at 6:25 AM
STEVE W.
  • 15,413 POSTS
If they are both the engine symbols but one has an arrow, you have a problem. You need to get it scanned, the engine with the down arrow in it means you also have reduced power.
Once you have the codes that are stored post them here and we can see what the issue is.
It could be as simple as a loose connection or a bad interior engine issue. Also please post the engine size and transmission type.
Feb 22, 2018 at 11:54 AM
