Hi guys, you have alsways been correct in the past, Again, I need your infinite wisdom. I removed the air intake houseing, you know the tube the air goes through before it goes into the air intake. I cleaned the tthrottle body flapper valve with berrymans. I may have contaminated the MAP sensor. Now the check engine lighth comes on. I can remove the negative battery post and after 5 mins replace and the light goes out. Good thing except after about an hour of driving it comes back on. The code returned is P2282. From the Autozone computer it says the MAP sensor has failed. In have checked the connections and they seem OK. Do you think it is the MAP sensor? the part is about $100 and I would like your opinion before I replace. Thanks and i am eagerly awaiting your reply. BTW the car seems to be running great but i don't think it will pass inspection with the check engine light on.
Jul 25, 2009 at 11:03 AM
