Check Engine light with code P0171?
78,700 MILES • 2.5L • 2WD • AUTOMATIC
TASHA_01
I got an oil change yesterday and today my check engine light came on. I took it to two different auto shops, and both came back with the same code of P0171. I haven't noticed any issues other than it is making a lot of noise when I accelerate, even a little tap and it's revving like crazy. Thank you in advance!
Jul 11, 2022 at 12:31 PM
  • 110,248 POSTS
The code indicates there is a lean fuel mixture. Since you just had the oil changed, I suspect either the air filter box intake tube or a vacuum hose has been loosened and not properly installed causing a vacuum leak.
Take a look through this link. It explains how to locate and repair a vacuum leak. Try this and let me know the results.
Jul 11, 2022 at 2:52 PM
