P0303 code
2002 FORD EXPLORER
150,000 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
FORDHOG
Check engine light came back on after changing the spark plugs, wires, coil pack, number three cylinder fuel injector. The obd codes were 303 and 316, misfire in number three cylinder and misfire on first 1,000 revolutions. Reset code but engine still runs rough and check engine light is still on. What next?
Oct 2, 2019 at 11:33 PM
FORDHOG
I have reset the computer to clear, started the car, ran it for a minute, shut down, then rechecked codes. Still got a PO303 and PO316 for a misfire in #3 cylinder and a misfire after the first 1,000 revolutions. check engine light still on and still runs rough.
Oct 4, 2019 at 1:06 AM
SCGRANTURISMO
  • 4,897 POSTS
This might be a problem with the compression in cylinder #3. Could you please do a compression test of your vehicle's engine for us. Here is a link below explaining how to do this, if you are unfamiliar with the procedure:
Please go through this guide and get back to us with the results. We can go from there.
Thanks,
Alex
2CarPros
Oct 4, 2019 at 4:48 PM
SLYJACKSON
I've changed the wires, plugs and the coil. The engine still runs rough at startup and I get the PO303 code. I have also check the valcuum line as well. This is really getting annoying. Do you think it may be the EGR valve ? I'm told that it may also be a head gasket problem but I don't seem to have lost in water in the radiator or reservoir. Any help is appreciated.
Dec 21, 2020 at 5:48 AM (Merged)
MERLIN2021
  • 17,250 POSTS
If you have done a vacuum check, and no leaks found. Test the injector at cylinder 3....Use an ohm meter on the other injectors to determine what the reading is, then check #3...Use a noid light on it to test the harness, they are cheap, and sold at part stores...
