How to reset check engine light?
156,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ASTRA27
  • 5 POSTS
I have the car listed above and it had a check engine light on for codes P0016 and P0017. i took it to a shop and had them replaced they told me to drive it 200+ miles and I did that but it’s still on and my emission monitors won’t turn on. I need help I can’t even register it with the check engine light on and no monitors on.
Dec 9, 2021 at 6:37 AM
  • 110,246 POSTS
If you need to simply reset the check engine light, here is a link that explains how it's done:
https://www.2carpros.com/articles/check-engine-light-clear-codes
Here is the issue, if you are referring to the monitors' readiness resetting, this will not do it. Actually, it will cause all monitors to start over.
If it is the monitor readiness you are waiting for, it needs to be driven.
Let me know specifically what you are trying to do.
Dec 9, 2021 at 9:59 AM
ASTRA27
  • 5 POSTS
So, the check engine light is on for those two codes and my I/M monitors are red except for the heater I’m trying to get the check engine light off, so I don’t have to look at it anymore and I’ll try the Drive cycle for the emissions.
Dec 11, 2021 at 3:00 AM
ASTRA27
  • 5 POSTS
I’ve tried to clear the codes, but it keeps coming back after I drive it and turn the car off and turn it back on.
Dec 11, 2021 at 3:03 AM
  • 110,246 POSTS
Are the same codes returning after you reset it? They are, as I'm sure you are aware, to the crankshaft position sensor and the camshaft position sensor. If they have been replaced, there is still an issue. If both came on at the same time, there is a chance the timing belt is stretched or there is an electrical issue such as a poor connection, damaged wire, or even an issue with the PCM.
Let me know if they are the same codes that return.
Dec 11, 2021 at 1:01 PM
ASTRA27
  • 5 POSTS
Sorry for the late reply, but these are the other codes it throws up when I was investigating further.
Dec 24, 2021 at 4:42 PM
  • 110,246 POSTS
The codes indicate a timing-related issue. The timing between the crankshaft and camshafts is off.
Now, that can be the result of a faulty camshaft position actuator valve, a timing belt that has jumped time, or even stretched timing belt.
Has the timing belt ever been replaced? When it is running, does it seem to have normal power and run smoothly?
If you look below, I attached the diagnostics and descriptions of these codes. Note: they are both listed together.
Dec 25, 2021 at 12:13 PM
ASTRA27
  • 5 POSTS
So, the car feels like it wants to go but I have to push on the pedal twice for it to go faster but I don’t know. I don’t know if the timing belt has been changed but I’m thinking more than likely not. I recently got ahold of a mechanic to see if he knows anything about it. He told me it might be the timing belt and he mentioned that if I replaced the timing belt it’s better to replace the water pump also instead of dealing with it later.
Feb 19, 2022 at 3:58 AM
  • 110,246 POSTS
It is very possible that the belt has stretched, or even jumped. If it has never been replaced, that is a good idea to at least have it inspected.
The idea that the water pump should be done at the same time makes sense as well. If you don't replace it and it fails, you will have to basically pay the same for labor to replace the pump by itself as you did for the entire belt procedure.
If you plan to do it yourself, I attached the directions below.
Feb 19, 2022 at 5:09 AM
