reverse to back it make a sound and engine move little bit
86,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MENA EZZAT
Check engine light opened , when i go speed rpm not working suddenly. 1- when car go it didnt go to drive 2 and 3 so transmmition not workig
2- when i go to repair mechanic check computer and said transmition is good but the code said that i should change transmition range sensor so i change it but the light of check engine still opened so he said i should change the speed sensor as the 2 sensor work together and also i should the bottom labor of engine to stop the sound come when i make revers
Aug 19, 2014 at 8:35 AM
HMAC300
  • 48,601 POSTS
have the trans guy check it kinda sounds like it time for a rebuild
Aug 19, 2014 at 11:39 PM
