codes p0440
210,000 MILES • 4 CYL • AUTOMATIC
KOLLMAL
Shop gave me codes p0440, p0441, p0446, said car needs canister, purge valve and fill cap. Quoted $1,625.00 parts and labor. Is the cost reasonable? Is it worth it to even fix? :-(
Feb 9, 2019 at 1:05 AM
BMDOUBLE
  • 1,139 POSTS
Canister purge valves are common to get stuck open and pull a constant vacuum on the tank, thus with a full tank it has the capability of pulling in raw fuel and filling the canister. But most common is when you go to have your vehicle’s oil changed and the technician checks your air filter and doesn’t re-connect your vacuum lines to your purge valve.
Feb 9, 2019 at 6:55 AM
BMDOUBLE
  • 1,139 POSTS
$1,625.00 is way out of the question imo.
Feb 9, 2019 at 6:56 AM
KOLLMAL
Thank you, but he was saying we needed a whole new canister, a new purge valve (isn't that a separate item?), new vent valve and filler cap. I was picturing these were all separate items, no?
Feb 9, 2019 at 8:00 AM
KOLLMAL
I could be all wrong. Appreciate your help and further explanation. Thanks! Lynn
Feb 9, 2019 at 9:11 AM
  • 55,770 POSTS
Here is the prices and labor times to do the job and how the job is done in the diagrams below:
Vapor Canister 7774006111 - $381.42
Labor 2.1 HRS
Vacuum Switch Valve 1.1 HRS
Feb 12, 2019 at 2:20 AM
