Check engine light on
70,000 MILES
CEVYTRAXOWNER123
Check engine light has been on I am wondering if it could be from a light that's says "service stable trax". So, I want to know if that could have something to do with it.
Apr 1, 2022 at 1:17 PM
  • 110,248 POSTS
Yes, that is the likely cause. The service stable Trac light is likely related to a faulty wheel speed sensor.
If you haven't had the computer scanned, I recommend doing that first. Because of the model year, I recommend having the can-bus scanned.
CAN stands for controller area network. Basically, the different computers/modules in the vehicle are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link showing how it is done:
Let me know what codes are retrieved so I can better direct you.
Apr 1, 2022 at 3:45 PM
