The truck is running smoothly cold and hot. Code P01071 turned on light. Codes P0174 and P10102 were also present but had not triggered light yet.
Jan 4, 2018 at 3:14 AM
✓Experienced Mechanic
We do not know what the P01071 is it needs to be five digit but the lean mixture code P0174 is usually caused by a cylinder misfire or the MAF sensor needs to be replaced. I would use all AC Delco parts to do the tune up with wires as well. I would also get the MAF for ACDELCO as well.
