Check engine light on
61,500 MILES • 5.3L • V8 • 4WD • AUTOMATIC
THANH808
  • 8 POSTS
Hi every one, my name is Alan from (Honolulu). I have an SUV my engine light came on two weeks ago, then take dealership services , the dealership check out is problem,(bank 2 sensor 1 oxygen sensor) is problem,too rich and lean. I have change new oxygen sensor, am say good find out the problem, just go for it to change new oxygen sensor. after five days of driving ( engine light back on again), then take back dealership ask why my engine light back on again, after they check same problem again (bank 2 sensor 1 oxygen sensor ). they known change new one two weeks ago. also, they said it will turn off by itself.
Nov 17, 2016 at 3:07 PM
HMAC300
  • 48,601 POSTS
it wont turn off by itself you need a scanner to do it. check fuel pressure with a gauge it may be a pressure problem. auto parts rent gauge see link.
have them scan for codes and get back with correct code.
Nov 17, 2016 at 11:23 PM
