Good afternoon.
2122 is for the pedal sensor. before replacing I would verify the 5 volt reference circuit to be sure it is not a wiring issue.
Symptom/DTC P2122
Descriptor
Accelerator Pedal Position Sensor # 1 Low
Low Voltage At The App Sensor
Probable Causes
5 Volt Supply Circuit Open
5 Volt Supply Circuit Shorted to Ground
Accelerator Pedal Position (APP) Sensor
Accelerator Pedal Position Sensor (APPS)
Accelerator Pedal Position Sensor (APPS) 1 Signal Circuit Shorted to Ground or Return
Accelerator Pedal Position Sensor (APPS) 1 Supply Circuit Shorted to Ground or Return
Accelerator Pedal Position Sensor (APPS) No. 1 Signal Circuit Open
Accelerator Pedal Position Sensor (APPS) No. 1 Signal Circuit Shorted to Ground
Accelerator Pedal Position Sensor (APPS) No. 1 Signal Circuit Shorted to Sensor Return Circuit
Accelerator Pedal Position Sensor (APPS) No. 1 Sweep
Engine Control Module (ECM)
Intermittent Condition
Open Accelerator Pedal Position Sensor (APPS) 1 Signal Circuit
Open Accelerator Pedal Position Sensor (APPS) 1 Supply Circuit
Open Circuit On the Ratiometric Wire
Open Circuit On the Supply Wire
Powertrain Control Module (PCM)
Ratiometric Circuit Shorted to Accelerator Pedal Position Sensor (APPS) Return, Battery Negative, or Sensor 1 Return
Ratiometric Circuit Shorted to Hot Idle Switch Circuit
Ratiometric Circuit Shorted to Idle Switch Circuit
Supply Circuit Shorted to Accelerator Pedal Position Sensor (APPS) Return, Battery Negative, or Sensor 1 Return
Wiring Harness or Connectors
Mar 9, 2018 at 7:09 AM
